Murphinius
Unable to edit overide in "Ci tools Doors _ Schedule" Object - Door and Window Schedule all Dashed
I’m having an issue in Graphisoft Archicad 29 using the "CI Tools Door _ Schedule” tool from the Monolith library?
All door and window outlines in the schedule generate with a dashed (hidden) line type.
This appears to be caused by the this "CI Tools Door _ Schedule”object having Override turned on in the 'Floor and Section > Symbol Lines' setting, but there doesn’t seem to be a global way to disable this across all elements.
I can manually fix it by going into each individual door/window and changing the symbol line type to solid, but when the schedule updates it reverts back to dashed.
I have tried Resetting the CI Tools schedule object, adjusting Model View Options, checking Graphic Overrides, cleaning attributes, rebuilding the schedule after editing overide setting, and redownloading Ci Tools, but the issue persists.
I’m trying to find a way to globally control or disable this override without editing every single door and window individually everytime.
Operating system used: Mac Apple Silicon Sequoia 15
1 Reply 1
Josh Osborne
Hi - it sounds like it's just a case of the Object Default Settings being setup wrong
To fix it, open up your schedule viewpoint, and then with No Elements Selected, double-click on the Object tool to see the default settings of the Objects.
Make sure it says this:
In there, turn Off the linetype Override, or if you do want to override the standard Solid Line, set the Symbol Lines setting to whichever line you want to override with, and then just hit OK
When you next rebuild the schedule, it will use those new object tool default settings
Let me know how that goes - also for any future Ci Tools queries, you can email us at [email protected]
Josh Osborne - Graphisoft
