Unable to import 2D RFA file
When I try to import a 2D .rfa file via the Files > Library and Objects > Import RFA as GDL object. I get an error message that says: The selected RFA file could not be imported. No 3D geometry was found.
If I have to import 3D RFA only, how can I import the 2D RFA which would be used similarly to the DET_??? objects?
Thank you.
0 Replies 0
