Unwanted text on doors and windows
When I insert a door or window into a wall the new object is accompanied by text saying "Custom" and then showing the door/window dimensions. I can't find any settings in parameters or elsewhere related to this text. How do I get rid of this text?
Thanks.
1 Solution
David Maudlin
HarryN:
It is the Door or Window Marker. In the Door or Window Settings it is in the Dimension Marker panel, where it can be set to "No Marker". If you want the Markers for some Views, the use Model View Options > Construction Element Options > Door Options / Window Options > "with Markers" to control their visibility.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
2 Replies 2
David Maudlin
HarryN:
Thankyou, that worked, much appreciated.
