MuriloNoleto
Update library parts advanced
Hello everyone,
Has the "Update library parts advanced" Library Developed function discontinued in AC 21/22 versions? Is there another way to hide scripts?
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 29 | Win 11 |
3 Replies 3
I am not sure what “update library parts advanced” is, but to hide the scripts you just need to set a password and then save the object.
Don’t forget the password as there is no way to open the object without it.
MuriloNoleto
Thanks for replying Barry.
Update library parts advanced is a "hidden"command from Library Developer menu, this menu must be enable though Windows Registry Editor, in AC 18. Now I see that from AC 20 the command is no longer available.
Anyway, setting password is also good way to keep scripts.
M
Murilo Noleto
Lingwisyer
Guru
You can also hide individual scripts themselves by editing an xml version of the object.
https://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/AC_15/APIDevKit/LPXML%20Docu...
Make sure you keep a copy of the xml or uneditted gsm as the editted gsm will only produce empty scripts.
Ling.
