2007-04-20 06:26 PM
VALUES "array_1" RANGE [min_space, A - min_space], AThe purpose is to prevent any of the arrayed elements from approaching the left or right sides too closely, but still allow the right most one to snap to the overall width.
2007-04-20 09:07 PM
but Frank must be busyReally funny. But thats the way you get me.
I understand that the values apply to all elements of the array and cannot be applied to single entries within the array.Right and not. If you use array- UI_INFIELDS in user interface and have only single fields on one page you can differ between the the fields, but this does not work in plan view anymore and is another theme.
I can stretch to any length regardless of the apparent value limits.There is a different behaviour, if you use RANGE und CUSTOM in combination or exclusive. Adding STEP and CUSTOM in one VALUES command could be paradox too. I have mentioned that in betatest 10, but haven't heared anything about it anymore. Maybe they have changed something (senseless) by my note.
2007-04-21 01:59 PM
2007-04-21 09:35 PM
