ā2017-11-24 11:33 AM
DIM sarray[]
! file in the library, containing parameter data
filename = "ProjectNotes.txt"
ch1 = OPEN ("text", filename, "MODE=RO, LIBRARY")
i = 1
j = 1
sarray[1] = ""
! collect all strings
DO
n = INPUT (ch1, i, 1, var)
IF n > 0 AND VARTYPE (var) = 2 THEN
sarray = var
j = j + 1
ENDIF
i = i + 1
WHILE n > 0
CLOSE ch1
! parameter popup with strings read from the file
VALUES "RefNote" sarray ā2017-11-25 08:35 AM
ā2017-11-25 08:55 PM
JGoode wrote:Create var parameter, or declare var = 0 in the script. And there will be no mistakes.
I keep getting an error on the "IF n > 0 AND VARTYPE (var) = 2 THEN" line
I don't know what's causing it or how to fix it.
ā2017-11-30 07:51 AM
if n > 0 then
if vartype (var) = 2 then
