W Glass Block Wall 16 - Trim Material
I am looking to use the "W Glass Block Wall 16" Window. I do not see the Casing and trim specifications and how to change the material of the trim.
1 REPLY 1
Here is a work around:
Place a fixed window first, change the ID to something you can easily exclude from your schedules, and set marker to none,
Then place the glass block window in exactly the same spot.
I found it easiest to place the block window to the side then drag it on top of the fixed window.
