Wa_oplines Error
I am working on a project in AC9 using the AC9 Library windows.
In opening a Section I recieve the following errors. How do I get to the bottom of this?
5 Replies 5
The offending window was the "W Fixed". The problem occurred when I attempted to copy Settings from the "W1 Casement" onto the "W Fixed".
I would guess (without having time to look at the code) that the problem arises from applying the parameters from an operable sash to fixed glazing. You should be able to fix it by reseting the fixed unit to defaults and adjusting the parameters manually.
Aussie John
Type command L into the script window and you should see a divide formula. If you are lucky you will see a parameter as the denominator which has been set to zero.
In the end it may be quicker to use Matthews suggestion
Cheers John
[/size]
Frank Beister
If you use explicit only the AC 9 library, why do you get a wa_oplines_81 error? Mixed libraries?
This is a fair question and one that I wondered about myself. I did not wonder long because it seemed the GS in the past have had "overlapping" library content. Hopefully the other here can answer this question as as to whether it is important.
For what it is worth, I selected the AC9 window and Ctrl-Shift-O (Opened object). The window states "GS Corner Window 81". No ideas here...... I just work here.
