wall skins cause door errors
I don't know if anyone has seen or reported this as but we discovered today that
if - your wall is a composite structure
and - you set one or more of the dividing lines between skins to "hidden"
and - you set the wall to display per the structure's settings
and - the door "general settings/walltype" is set to "brick veneer" or "stud wall with siding"
THEN
the door (D1 commercial, etc) generates the following error
pen number is less than 1 or greater than 255 at line 1003 in the 2D script of file wa_trim_us_10.gsm.
hope this helps if anyone else is having this trouble!
Frank Beister
Looks like a bug in the macro. Report it to GS per mail please. You can fix it by your own to avoid error message, You have to modify the certain line (1003 ) in the script. Jump to it by Command-L in the macros 3D-script.
There has to be something like
PEN WALLSKINSPARAMS[...][7 or 9]
in this line. The pen number aftre PEN may not be less than 1. You can proof this by
IF WALLSKINSPARAMS[...][7 or 9]>0 THEN PEN WALLSKINSPARAMS[...][7 or 9]
[...][7 or 9] you have to change as it is written in the line.
Make shure to have a backup of the GSM before you do any changes. 😉
