Wall Accessory BUG?
HI!
I found that the arc wall has a small bug. I used the Accessories library 22 to test it. When the wall is connected at a small angle, it does not work.If the two walls are disconnected, the arc wall will work properly.
2 Replies 2
Lingwisyer
Guru
The arc wall is bugged? What should we be seeing? Or is it the accessory that is bugged and it is not generating?
I just checked it and it is the accessory that has the problem.
Slightly different geometry of the wall and there was no problem.
It seems to be just this particular angle that the wall meet at.
