We value your input!
Wall End Object no contours
Is anyone having problems showing it in elevation. I can't get the contours to show?
4 REPLIES 4
Which wall end object?
"Cased End 13"
I have Arkiklub-Australia checking on it with no joy as yet.
I'm seeking other users' opinions on it.
It has become a critical part of our drafting conventions.
ztaskai
Graphisoft Alumni
Graphisoft Alumni
Yes, there has been a report about this phenomenon earlier. The contour disappears in case you set the thickness of the "side wings" to zero. As a workaround I suggest you to set it to 1mm.
I scheduled a fix of the 0-thickness for AC14.
Sorry for your inconvenience!
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Thank you ztaskai. I will pass on to the guys.
Is there no chance for a V13 hotfix? It has been around in V12.
Please also check on "open GL" view as contours not showing also.
Do you know when 14 is going to be ready?
