In a bid to spread the love (and today being AUSTRALIA DAY !!), I am posting a tiny little wall accessory I made that lets you show a walls outline in other stories.
This is the 2d Script from our main wall accessory that we sell to local users. The "main one" will do 3d footings/thickenings/internal and external wall skins/wall plate/brick build up etc etc.
After installation into your local library
Select all the walls in plan and go extras/accessories/wall accessories then choose the "Wall Lines" accessory. Set "Show on" to one story above or one story below or all stories then click OK.
With a bit more scripting you could get it to show on a range of stories but I will leave that bit to you.
Hope you find it usefull.
ps.. some of the connections dont resolve 100%. Any suggestions for the fix would be appreciated.
I should of pointed out that you cant see the part after you have created it.
It is only visible from another story. But if you turn off clean wall intersections a line appears to the outside of the reference line and the part can be selected
