2026-06-10
03:52 PM
- last edited on
2026-06-10
08:57 PM
by
Hi, anybody have this problem with mep plumbing hotlinked modules? using iceberg method, the accessory dimensions change.
Operating system used: Mac Apple Silicon Tahoe 26.4
Solved! Go to Solution.
2026-06-16 03:23 PM
Hello there,
Thank you for bringing this issue to our attention.
This behavior is connected to an already known problem, which is registered under DEF-26294. It is a collective issue that affects the hotlinked MEP elements in multiple ways unfortunately, including the mentioned diameter change. The core of the problem is that the Table of Dimensions is lost when hotlinking, even though the source and target files are the same.
I linked your report to the existing DEF ticket in our system to help raise its priority. Hopefully, Product Management will consider fixing the root cause in a future Archicad version.
I'm sorry for the inconvenience.
Kind regards,
Kornél
Beleznai Kornél
Senior Technical Support Engineer
2026-06-10 06:32 PM
Plumbing labels also have problem updating hotlink modules
2026-06-10 08:59 PM
Please report this to your local reseller if it turns out to be a bug.
2026-06-16 03:23 PM
Hello there,
Kind regards,
Kornél
Beleznai Kornél
2026-07-02 06:16 PM - edited 2026-07-02 06:17 PM
I'll wait for the solution. I generally use modules for MEP, and it's important that the path definition tables and labels are operational.
2026-07-31 01:34 AM - edited 2026-07-31 01:46 AM
hotfix 5101 doesn't fix the issues with the Hotlinks in MEP; I was hoping to find them resolved.
this note: "All relevant improvements and fixes are also included in the corresponding MEP Designer version." it's not real
Tuesday
i tried it in archicad 30 and still have this issue
