Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Weather Veins
Hey Everyone,
I am looking for a Weather Vein to put ontop of one of our Gazebos. The Archicad 10 library does not have one, and I am unsure how to make one. Does someone have one that they have made? Or know where I can find one??
Any help would be wonderful!! Thanks!! Michelle
4 REPLIES 4
Dwight
If there actually isn't a weather vane, it is easy to make using the Complex Profile Tool.
Do you want a rooster, a duck, or a horsie?
Perhaps you want a weather vane like the one foretelling the tornado disaster in last week's Despicable Housemarms where the sun shines from the North in the scene. And it is the Northern Hemisphere! AAAArgh! Like no one would notice! Such amateurs! But a great tornado! They must have rented every wind machine in Hollywood for that!
Make a complex profile guidefill shaped like the animal and the arrow and then use the beam tool in the perpendicular direction. You make a shallow extrusion equal to the casting depth.
Then another one perpendicular without the animal.
Dwight Atkinson
If you want the compass directions, you can use the 3D Text object.
If you want a winged horse, you would need a second profile facing the other way.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Srinivas
Not sure if this is of any help, but I saw a tutorial on how to make a Weather Vein on the ArchiForma Website some time back using ArchiForma, but couldn't find any thing now.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
there are a couple at google's 3D Warehouse you could try and import, just search for 'weather vane'
