ā2006-02-05
04:38 PM
ā2023-05-26
11:40 AM
Rubia Torres
ā2006-02-05 05:04 PM
ā2006-02-05 05:40 PM
ā2006-02-05 05:52 PM
ā2006-02-07 03:05 AM
ā2006-02-07 09:30 AM
I am using the SE9 Library by the way. I don't see a green diamond that I can move or adjust. How do I get this to show up? Is it part of the SE9 Library?You should be seeing the green diamonds when you select any hot spots of the window or door objects. Are you sure you are using the latest SE9 Library? Anyway, to see the diamond hot spots and the direction they can be moved in go to the "Marker Settings" tab > set the first dialog to "Marker Geometry" > go to the last dialog at the bottom of the tab and check "Show Editable Hotspots".
ā2006-06-29 04:13 PM
ā2006-06-30 01:41 AM
ā2006-06-30 09:40 AM
ā2006-06-30 12:25 PM
