What's up with Relational Operators
I have objects that ref. the parameters list for operation
Why do I get the "Use of real types can result in precision problems"
Example:
if ptch="0/0" AND DISTCUT1>=0 AND DISTCUT2=0 then total_length=-A
how do you work around this. It worked fine in 7.0 8.0 what's up with 9.0
Please any suggestions
1 Reply 1
Example:
Please do a 'search' of this forum for a lengthy discussion of this. Try searching for the term 'epsilon'.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
