Where are the restrooms?
Specifically, the toilets seats?
I can't find anything to create a bathroom in the object library.
7 Replies 7
Please click "Profile" near the top of the page and fill in your AC version and machine specs so that people know how to answer.
There are toilets (with seats, not individual seats), etc in the library.
If you cannot find them (use the Find option of the object dialog if necessary), then is it possible that you have AC 12 and also have the MEP add-on? With MEP, all plumbing fixtures (and more) become MEP equipment objects and have to be inserted with the equipment tool.
I have ArchiCAD 12, 2156 Int.
And I'm looking for the full toilet, right, not just the seats.
I don't know what is MEP.
I'm new to ArchiCAD and I'm using the Trial.
OK... your info helps. Since you have the INT (international) library and not the US library, the toilets may be called WC / water closet or something.
Use the object tool (chair icon) and browse through looking for a plumbing fixture folder, etc. You'll find toilets, tubs, etc, if the trial came with the full library anyway.
PS You might change your location to your proper location too. Your IP shows you are using a Mexican server, yet your profile says you are in the US...?
Thank you!
I finally found them!!
Well... now I can't take a shower
There are no showers.... just one with the type with a hose.
They usually are complement for a regular shower.
I already searched the library by name.
And there's nothing in furniture/bathroom accessories either.
vistasp
Mentor
Try the object in this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=24966
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Stress Co_
...down the hall, first door on the left.
Check the pull down Help menu for "ArchiCAD 12 Library Preview"
It'll show all the available objects (USA full version, anyway) and there location in the Library.
Marc Corney, Architect
Red Canoe Architecture, P. A.
