Where can i find a stacker glass door
im trying to find a stacker door like this....
6 pannels. 4 center ones open, 2 to each side.
i can only find stackers that stack to one side.
also after a corner stacker door if theres one aval
9 REPLIES 9
vfrontiers
I've tried to create one... many, many years ago. I find the best solution is to create an empty opening and place in individual doors. Save an EMPTY OPENING with all the SCHEDULING PARAMETERS so you can use it in your schedule.
It's a crappy answer for sure, but seems I have less and less time to dig into gdl anymore.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
You can do this with CadImage Door & Window Builder easily. I have never tried a corner one but will give it a try and let you know.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
__archiben
no question: cadimage door and window builder.
(regarding the corner condition - i've only been able to produce one with a corner post. you can model it without so that it appears the whole corner slides back, but this involves butchering the plan/elevation/schedule. i have the same problem now for the building in the screenshot. i've been trying to figure it, but no luck yet...)
~/archiben
b e n _ f r o s t
cheers guys.. we dont have cadimage.. il have to see if the bos is willing to hand over more $$ for us to buy it. i had a look on there website and i can see they have quite a few other tools worth having.
get David Sanders door objects from the object depository here, he has made a great one. you may need to rescript some of the pen settings to conform to your pen sets, though.
yeh i have that.. it has a door like what i want but is a pocket door..
He must have posted an update, my set has both a pocket and a stacking slider. there is a missing trim macro though, but that is easy to fix
perfect
iv noticed the missing macro tho.. no biggy but it is getting anoying having he warning pop up all the time letting me know.. how do i go about fixxing this???
Thanks for the tip, theses doors will be very used!
Thanks
