Where is the oversize parameter?
In AC10 and AC11, the 'oversize' parameter is missing in the window and door library parts...Does anyone know why? Is there a way to add this parameter to the AC11 windows?
12 REPLIES 12
Again, the Oversize parameters are only available for storefront in the US Library; however, I do see that they are available in ACE Library parts.
Laura, perhaps the parameters are hidden from viewing in the Object's settings dialog, but could be turned on if you open the LibPart. I had the same problem with Terrace Door 1 11. They were hidden under "AC Details" with blue colour!
I opened a window library part, and the oversize parameters are there, just hidden. In my experience, if a parameter has been hidden, there is a logical reason -- you could "unhide" the parameters, but I doubt it would produce desirable results.
