rob2218
Where is the "CENTER LINE" symbol in Archicad text?
Where's the center line symbol in the Archicad text??
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
8 Replies 8
Please go to this link and download the center line symbol library part.
http://www.onland.info/archives/2006/06/centerline_sym_jm9.php
Peter Devlin
rob2218
Thanks Peter,
though...I went to the site, download a file called "Electrigon" or something like that which contained multiple GSM objects in it as well as Fixture schedule XLM files.....what and how do I get the "center line" symbol out of those GSM files?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
OK....Peter, was able to "open" the object and it gave me a dialog box but from here, what do I have to do?
How do I physically "get" this object into my file???
What are the steps?
i>u
Edgewater, FL!
SOFTWARE VERSION:
If you go into the font character set you should find one that is the cl superimposed. Nuisance to find but once you have it works just great. Place text box centre justified with central anchor and it should always sit on your reference line no matter what scale.
Since it is an object, you use the object tool and find the object
and place an instance in the Plan or the Section/Elevation window.
Remember this is a 2D only object so it has no 3D representation.
The object must be in one of your loaded library folders for the
object tool to find it.
Peter Devlin
rob2218
Font Character Set??? Please explain.
i>u
Edgewater, FL!
SOFTWARE VERSION:
When adding text, click on add symbol button, then browse in your font (example here is ISOCPEUR)
vistasp
Mentor
When using the Character Map to find the symbol, one thing to keep in mind is that all fonts may not contain such a character. If you are working solo and sticking to standard unicode fonts it's not a problem but, if you're sharing files with someone who might not have the same font loaded, that person could well see a blank rectangle.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
