‎2023-02-20
04:09 PM
‎2025-01-02
03:34 PM
Molinda Prey
Hi, I'm looking to create a window with the Window 26 object in Archicad 26, but it seems to lack some options that the 24 Windows had. Mainly it's missing the option to include an apron/bottom casing underneath the interior sill/board/stool. Has anyone found a workaround? Considering just using the 24 windows but it'd be nice to be able to use the most up-to-date objects.
Screenshots attached of 24 window options vs 26 window options.
Solved! Go to Solution.
‎2023-02-20 05:46 PM
Are you using a different localisation of 26 than you were for 24?
‎2023-02-20 06:06 PM
Yes, just checked and I was using 24 USA, now using 26 INT. Would this make a difference?
‎2023-02-20 06:53 PM
Just installed 26 USA, didn't realize the library parts are different for each localization. Thank you!
