Window/Door Casing setting
Hello,
Curious if anyone has noticed that there are no window/door casing setting that controls the left and right side independently. In the first version of Archicad 13 library this was possible. Why would this great function be taken out? Any workaround?
Thank you
3 Replies 3
I've opened the object and looked at the GDL script and there is a line that shows "Casing left", but it is grayed out?
Ideas?
Erika Epstein
AC default windows and doors have uniform settings. Try selecting the ganging option as this will allow you to set sides differently.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Turning on the ganging option doesn't change the settings for the casing?
