trying to find the log home objects i use in v6.5 - HELP!
i just upgraded finally to to v13. i cannot find all of the log home objects that were made. archicad used to have a log home objects package (trusses, stairs, rails, beams etc). does anyone know where i can find these objects and other log home stuff? thanks
Stress Co_
I think the "Log Home Library" is included with ARCHILOGS
Marc Corney, Architect
Red Canoe Architecture, P. A.
That is correct-the Log Objects are now part of ArchiLogs Designer & ArchiLogs Pro. These add-ons replace the Log Home Solution (LHS) and are currently shipping for ArchiCAD 12 & 13 with 14 coming soon in the US.
For the old objects from 6.5 did you retain the 6.5 library you were using when you upgraded? They should still be there and should be able to be loaded using the library manager. If not, the 6.5 install disc should have them.
