Window Graphics
Hi, Can someone tell me how to show windows in floor plan so that the casing is showing? The photo attached is without the casing. Cheers Scott
4 REPLIES 4
Erwin Edel
Detail level of window 2D symbol is set up in modelview options.
It's a good idea to have several set up for different scales / level of detail / stage of design. You can set up saved views for those scales / stages etc with scale, layercombination, modelview options, pen sets, dimension styles, etc.
Our company template has twenty odd or so of different modelview options to take a project from preliminary all the way to construction documentation (and some specials for fire safety, regulations zoning, etc), just to give you an idea.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thank you Erwin, I can't find the controls in model view options to be able to show the window and door casing/architrave. Maybe you could point that out. Attached ids the dialog box I am looking at. Cheers Scott
Are the settings you want in the "Detail Level..." section of the MVO settings?
Thats it. Cheers
