Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Turning composite skins to window at head
Gary Hudson Jeffrey
Is it possible to turn plaster/composite skins to window at the head in section view. We can do this in plan view but not section?
ArchiCAD 64 20 Solo
Windows 7 Pro 64 bit
Intel Quad Core i7 3770K
16GB RAM
2GB Nvidia Quadro K2000D
HP Designjet 510 24ā€ colour printer
1 REPLY 1
Erwin Edel
Not without modeling it, sadly. The floor plan is a 2D scripted representation (switch the window to Projected, you'll see the same 'problem' as the section).
Luckily we mostly use it for plaster and that is 15-30 mm max and doesn't show too much on the 1:100 / 1:50 scale.
There's probably a wish on the forum already to vote on. Probably up there with 'better stair tool' as long standing wish!
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
