Window Sill Value
Hi!
I have a question, there is a way to show sill height, in the marker, from to the top of the sill instead to the bottom?
Thanks
2 Replies 2
JLopes
Yes, add sill and set height above the slab.
|| JLopes ||
AC29 Port || Ryzen 9 5900x | RTX3080 | Win
Thank you for your answer.
But the dimension you show,If you cut a section through the window, represented the bottom of the sill.
