Window and/or door settings with composite walls
I'm having trouble in AC17 to make the door or window frame
to appear after the finish of the wall, it only attaches to the core elements.
This appears as if the door was installed first, and then the finish was applied.
I'm attaching 3 pictures so you can see what I'm talking about
[/img]
2 REPLIES 2
Second
This is the result i'm looking for, but not by shortening the wall. Is there a way of doings this?
Thank you!
