Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Window or Door Object
I am working on a design, my walls have a slight radius and I have doors and windows in those walls. When I go to my 3d window I get a report and warning regarding the following . . .
Not enough edges in generatrix.
at line 2739 in the 3D script of file Casing.gsm.
After clicking continue several times I get the report and can view my model. Any Ideas why the warning?
1 REPLY 1
Dwight
You'll have a zero value somewhere.
If you turn off warnings in preferences, it will only tell you once that there were errors.
Dwight Atkinson
