Window sash issue
I've created a Springlike window, single hung,with equal size divided lite but I would like the lower, operating sash to be 3high and the upper to be 5h. The default is the opposite and there doesn't seem to be a way to switch them. Thank you for any help with this. I am AC19 using AC window library
3 Replies 3
Lingwisyer
Guru
Can you provide an image of what you are trying to achieve?
I personally don't quite get what your window should look like from your description... "equal size divided lite"? A single hung window with a lower and upper sash, with a full height sidelight on either side?
Ling.
The horizontal divider in this sash has 6w x 3h sash above it and 6w x 5h sash below. I would like the opposite. Thank you for replying.
Lingwisyer
Guru
I don't think that the AUS library contains a window like that...
Still, for multi pane windows, we are able to set the horizontal and vertical divisions independently for each pane. The default settings being equal divisions between all panes.
Ling.
