Window sill/header height bug?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-12-12
12:54 PM
‎2023-05-26
02:10 PM
Rubia Torres
EDIT: After playing around with this some more, it seems like the bug only shows up BEFORE you place a window. It works as I think it should if you are editing an already-placed window.
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-12-13 06:01 PM
So, it seems to me that when the "Sill or Header Height" field is using the "Header to Story" option, and I modify the Height of the Window, the Height value field will update and display an incorrect result. However, when I place it, it turns out that it places it correctly. So for me, it is only the field that displays the incorrect result prior to placement.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-12-13 06:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-12-16 10:45 PM
Can you point me to the right direction? Are we talking about the same parameter?
Here is my test with a default setting dialog (before a window is placed). As you can see, I set the "Sill/Header value" to use "Header to Story 0", changing the window's height does not affect the other value.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-12-17 12:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-12-17 04:49 PM
After some trial-and-error, I managed to reproduce the issue. It happens if you switch to another type of door/window while changing the Default Settings. As Richard already pointed out, this is just a visual glitch, and won't affect the real position of the door/window. The
I entered it as a defect in our database. Hopefully, it won't be a difficult one to fix!
Thank you very much for reporting this, Richard! It is definitely a well-hidden one!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-12-19 01:12 AM
I entered the values in the Info Box, that is where I reproduced the issue, I have not entered the Settings Dialog.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-12-21 03:15 PM
Thanks for the new info! I just tried it out and indeed it happens with the Info Box. I updated the defect entry with this comment.
Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
