‎2017-11-0710:21 AM - last edited on ‎2023-05-2412:28 PM by Rubia Torres
‎2017-11-0710:21 AM
Hey everybody,
Im looking for a shortcut for an a,b values of a window.
Unfortunately, i can't find the command that responsible on those parameters in the work environment.
I know only the shortcut b that changes the windows vetically distance from the slab.
Is there any shortcut already? Or how can i create that command in the work environment.
I think there is no way to set shortcuts for these fields in the Work Environment. Dialog. There are several shortcuts that work in the Info Box, including T for Top Elevation and B for Bottom Elevation, but there are no shortcuts you can assign for the Width and Height fields and Doors/Windows.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
