godi
Windows on inner wall face
Hi, I would like to know if there's some way to automatically adjust the windows to the inner wall face.
It seems archicad always positioned the window in the exterior face of the wall and I must "manually" move it to the inner one, so every time I change the wall type to one with different width, I must adjust the reveal depth to move the window to the correct position in the plane of the inner wall face.
That's very annoying, some solution?
12 Replies 12
Erika Epstein
After adjusting the window position, save it as a favorite.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
godi
Imagine: I have 60 or more different types of complex walls, with different widths between 0,22 to 0,60 m, so I have to save so many favorites as walls types? and I must remember which favorite is the correct for every different wall?
I don't think this is a real solution, but thanks for the help.
Erika Epstein
Thanks for letting us know
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
godi
you're welcome
vistasp
Mentor
Have you tried flipping and then rotating the window to give you what you want? In the attached image, the window has a reveal depth of zero and is still on the inside edge of the wall. Hope this helps.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
godi
Yes, I can do that, and I can even turn the opening to inner face, but in this way I will have sill and blinds in the wrong position, and I will ruin 3d and section.
(excuse if these aren't the correct words of english version)
vistasp
Mentor
If you have shutters on then you're right that this will not work!
In such a case -- and I know you have 60 different complex walls! -- it might be quicker to adjust the "Opening Reference" lines rather than modifying all the windows (which will probably be even more numerous).
Whichever method you choose, don't forget to turn on some nice music before you begin!
= v i s t a s p =
bT Square Peg
godi
vistasp wrote:
.... it might be quicker to adjust the "Opening Reference" lines rather than modifying all the windows (which will probably be even more numerous).
Hi
Maybe it's a problem wit the translation, as evidently spanish AC version have different names for same functions, but I don't know what are the "Opening reference lines". Is this a parameter of walls or windows?
vistasp
Mentor
I hope the graphic explains what I mean.
= v i s t a s p =
bT Square Peg
