New (not BIM) server, same libraries
Hi all.
Converting our libraries' server (not a BIM server yet) from Server1 to Server2.
All files in the same places, relatively, but new server name.
Is there a quicker way to make the transition than manually re-linking all the libraries of all our active projects?
I'd love a command-line trick or two...
andrew
AC15 (build 3602)
a collection of iMacs (i5 and i7) running 10.7 Lion
server: Mac Mini (i7) with Lion Server
3 Replies 3
hmmm not that I know of off hand. I'll ask one of our engineers!
If you were on Windows you could just match the network drive mapping. On Mac I'm not so sure. Is there a reason you can't just name the new server the same as the old?
Matthew, I thought of that -we'd just "trick" all the applications (AC included) into thinking the same machine were there.
But we had a transition period in which we needed both machines active and on the network together. Probably could've thought my way out of that, too, but i didn't.
So, we're manually re-linking libraries. Not a tragedy, just a stutter at the start of each opening of a project that hasn't been updated. We're a small shop, so our Active list is 10-20, not 100-200, so it's not so bad...
thanks, all!
andrew
