Wired Rail Object
Hey! I'm adding this rail object to my project and I chose the Rail Wired 02 15. This rail has this wires attached to the posts but not in the center od the posts, either on the outside or the inside part of the rail. It works perfectly when the rail is straight but in the curved rail I can only have the wires on one of the sides of the rail, the exterior part of the curve. Do you know any fix for this or there's no fix at all?
Thanks,
P.
0 Replies 0
