2012-10-05 01:36 AM
!-- Getting NCC Table D1.13 valuesNot having done much work yet with arrays I'm now stuck as to the next step to use the value the user selects from the drop down for NCC_TableD113_Use to select the matching value for the NCC_TableD113_Rate.
dim value_use[], value_rate[]
filename= "NCCTableD113.txt"
ch1=OPEN("TEXT",filename,"SEPARATOR='\t',MODE=RO,LIBRARY")
!--counting the total number of rows
row=0
do
row= row+1
n=INPUT(ch1,row,1,string1)
while n>-1
!--reading the first column for NCC_TableD113_Use
for k= 1 to row-1
n=INPUT(ch1,k,1,string1)
value_use= string1
next k
!--reading the second column for NCC_TableD113_Rate
for m= 1 to row-1
n=INPUT(ch1,m,2,string2)
value_rate= string2
next m
CLOSE (ch1)
VALUES "NCC_TableD113_Use" value_use, custom
2012-10-06 08:33 PM
do
row= row+1
while n>-1
for k= 1 to row-1
value_use= string1
next k
values "NCC_TableD113_Use" value_use, custom
for k= 1 to row-1
n=INPUT(ch1,k,1,string1,string2)
if NCC_TableD113_Use = string1 then
values "NCC_TableD113_Rate" string2
endif
next k
CLOSE (ch1)
2012-10-08 01:13 AM
2012-10-08 06:48 PM
