2018-01-08 04:24 PM
CPRISM_ ...
COOR{3} ...
! Later:
CPRISM_ ...
COOR{3} ...
In this shortened example the first COOR{3} doesn't seem to take place at all / gets overridden by the second one.Solved! Go to Solution.
2018-01-09 02:34 AM
CPRISM_ ...
COOR{3} ...
BODY 1
! Later:
CPRISM_ ...
COOR{3} ...
BODY 1
2018-01-09 02:34 AM
CPRISM_ ...
COOR{3} ...
BODY 1
! Later:
CPRISM_ ...
COOR{3} ...
BODY 1
2018-01-09 09:07 AM
Barry wrote:Wow, thanks Barry.
Isn't that when you need to use the BODY 1 after the COOR?
2018-01-09 10:11 AM
2018-01-09 11:29 AM
Barry wrote:Yes, but have a look for yourself here.
I think it means that COOR{1} and COOR{2} are deprecated and replaced with COOR{3}
j1: closed body (deprecated)And it is not really verbose in everything else; that the BODY 1 is needed is never stated anywhere.
2018-01-10 02:37 AM
runxel wrote:Ah that is the 'status' in the BODY command.
It clearly statesj1: closed body (deprecated)
