Zone Stamp angle
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-02-11 05:53 PM
‎2019-02-11
05:53 PM
Is there any way to access the zone stamp angle that is set in the zone settings from GDL? even if you can only read it.
ArchiCAD 23
Windows 10
Windows 10
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-11 07:23 PM
‎2019-02-11
07:23 PM
Nope... I added another parameter to drive that using hotspot in my stamps ;(
Piotr
Piotr
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-12 01:53 AM
‎2019-02-12
01:53 AM
SYMB_ROTANGLE works for me.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-12 04:52 PM
‎2019-02-12
04:52 PM
not exactly - it cannot be modified via hotspot (or via parameter command) for example...but yes it is the parameter that is in the infoBox.
Piotr
Piotr
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-13 02:27 AM
‎2019-02-13
02:27 AM
Piotr wrote:No you can't modify it by a hotspot - but then you can't do that for any object.
But you can add your own rotation parameter and hotspot that.
ROT2 -SYMB_ROTANGLE first will undo rotation the user inputs in the info box if that is important.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-13 09:52 AM
‎2019-02-13
09:52 AM
I was refering (maybe I was wrong) _only_ to the ability to use that parameter for hotspots and so on...
Anyway all those parameters should work normally (hotspots and so on)
Piotr
Piotr
