Zones and calculations
I am working on a zone stamp to calculate the maximum occupancy of a space based off of the area and the allowable load factor. Everything is working as expected... except when the Zone area is changed. I run the Update Zones command, the Area is updated, but the maximum occupancy doesn't update. Does anyone know what scripts are run when the Update Zone command is executed? I wish the execution order was better documented. thanks in adavnced.
Never mind. I gave up too soon and posted here. Master script is the correct answer. Moved the calculation there and it auto updates.
