2011-02-14 12:24 PM
2011-02-14 02:14 PM
2011-02-14 02:27 PM
PARAMETERS ac_bottomlevel = Z~ PARAMETERS ac_toplevel = Z~+ZZYZXDo I need to do some changes of my 2d script code?
2011-02-16 10:37 PM
2011-02-25 12:54 PM
PARAMETERS ac_bottomlevel = 0 PARAMETERS ac_toplevel = ZZYZXIn a hanging object/lamp the parameter script should contain this:
PARAMETERS ac_bottomlevel = -ZZYZX PARAMETERS ac_toplevel = 0And so on...
TurboGlider wrote:
Thanks David, but I've read that thread and done the tip they talk about their.
My toplevel and bottomlevel are showing right value, even zzyzx, bottomlevel are = Z~ and toplevel are bottomlevel + zzyzx like I wrote above.
The problem is that the object start acting weird then I turn all relevant stories on. Even with normal setup in floor plan cut plane the objects shows only on topfloor even if bottomlevel and toplevel of object are on homestory of the object. And that story are 18 meters under topstory.
Parameterscript :PARAMETERS ac_bottomlevel = Z~ PARAMETERS ac_toplevel = Z~+ZZYZXDo I need to do some changes of my 2d script code?
