archicad objects
I am looking for some objects for pipe work and taps and also stool but the stool will be a long pole and wooden top on it and no bottom because it will be going into the ground.
These will be used on my student version off archicad 10 and wondering if there is a object maker so i can make these my self and will be used for my college assignment.
Thanks in advance as well for all the advice
3 Replies 3
Brendan,
There is a piping object on the free Object Depository at
archicad-talk.graphisoft.com/object_depository.php
I not quite sure of what you mean by stool but it sounds like you could use slabs for making this up.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 30-Latest USA
2024 M4 Max MacBook Pro-OS Tahoe (128GB (16 Core CPU + 40 Core GPU)
sorry its just like some that are already built in but i would like a more unique
A circular piece of wood 20mm thick and 300mm diameter with a metal pole going into the ground and be 300mm from top to ground level and about a foot into the ground
I have just used that piping object but how you get them to connect.
Horizontal and vertical together.
It will need to look something like this and it shows the stools as well
http://hometown.aol.co.uk/Thebigguy6434777/DSC01146.JPG
http://hometown.aol.co.uk/Thebigguy6434777/DSC01144.JPG
