2006-10-13 07:46 PM - last edited on 2023-05-24 12:46 PM by Rubia Torres
2006-10-13 07:57 PM
2006-10-13 08:51 PM
2006-10-13 09:29 PM
Thomas wrote:Do you have a window called "basic window" in your library? or do you mean any basic window from the library?
It's possible to get a similar window using the basic AC10 window (in the Int library,at least).
2006-10-13 09:45 PM
Hassanen wrote:Well, it's actually called "Basfönster 10". I'm currently using the Swedish object library, which basically is a translation of the INT library. I'm not sure of the INT name, and I can't load the other library at the moment, but I think its the most customizable window at the top level of the window section of the library. Maybe Mats Knutsson or Ben Odonnel can fill in?
I've never tried the stacked window approach, isn't it a hassle to move around and edit?
2006-10-15 11:25 PM
2007-01-10 03:05 AM
