can someone please help find the archicad 11 library subset
i run now on a archi 13 edu version but i have to finish some projects i started on an 11 and i learned from other topics here, i should use a migration library but i just can't find one! so please help!
3 Replies 3
If you are using the INT version then send me your email address in a Private Message and I will send it to you.
Do not post your email here unless you want some spam.
ztaskai
Graphisoft Alumni
Graphisoft Alumni
You may be looking for something like this:
http://www.graphisoft.com/support/archicad/downloads/ac13/INT/
HTH,
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
problem solved!
thanks a lot guys! most of all thank you Laszlo!
