cannot create custom door panel
I am trying to create a custom door panel following the path: file/libraries and and objects/save custom components, having selected a slab item, however the attached message appears. Does anybody know sth?
David Maudlin
evivas:
You are missing the Custom Object Macros 15 folder in your loaded libraries. Use the Library Manager to add this folder, it is in the ArchiCAD Library 15.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Solved! Thank you!!
