cannot create custom door panel
I am trying to create a custom door panel following the path: file/libraries and and objects/save custom components, having selected a slab item, however the attached message appears. Does anybody know sth?
2 Replies 2
David Maudlin
evivas:
You are missing the Custom Object Macros 15 folder in your loaded libraries. Use the Library Manager to add this folder, it is in the ArchiCAD Library 15.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Solved! Thank you!!
