chairs off set in 3-d
i am using a chair from the archicad 11 library. I set in in plan, and in 3-d it is offset from its orginial location... i've looked in the object settings.. but can't figure it out... help please!
6 Replies 6
David Maudlin
kbot:
You are right, the object is Office Chair 02 11, and the 3D hotspots are correct, the model of the chair is offset. Whoever wrote this part should fix it.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
its like this on most of the archicad 11.lib chairs.
is there a way to adjust it?
Link
Do you have the latest library? GS just released build 1114 of ArchiCAD. Maybe they have released a new library. I am still using the library that came with the US build 970 and my office chair is fine.
Link.
David Maudlin
According to the updates page, everything is ok.
Link
Do you have the same problem with the attached chair?
Link.
David Maudlin
Link:
The chair you posted is fine, I am posting the bad chair. The difference is in the 2D Script. My question is: for US users do they have the bad library on their site, or is their notification process not working properly?
Inquiring minds want to know.
