change the door and windows material
bibiarch
hi im new to archicad! I already used autocad and revit before but I'm having some problems with archicad. I want to know how to change the materials of my doors and windows. I changed the material of the walls and floor very easily in the default setting because there is "model" but I tried to the same with the doors and windows and there's not the same option please help
walls
doors and windows
1 REPLY 1
Ricardo Lopez
Hi @bibiarch
Materials are normally treated as building materials or as surfaces, depending on how parametric element was programmed. I encourage you to continue exploring the different settings of the library objetcs. These are usually in Model Attributes inside each part of the element, as you can see in this example image:
If what you need is to create your own surface or building material then go to: Options> Element Attributes>  Surfaces... or Building Materials...
More information can be found here:
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Setup info provided by author
