changing A & B values according to what you pick
I'm using the wall niche object combined with an object of my own to create something we can actually use. The problem is I want one object to work with 3 different sizes. So I want to add a line like
IF paramaterDuck=model1 THEN A=1'-5" AND B=4'-8" Can I add this to the master script. I added it to the 3D script and it looks fine in elevation but the 3D view and plan still shows the values for A and B that is in the dialog box. I hope I explained this well enough.
Thanks for any help,
Michele
4 Replies 4
Michele,
I believe there is something wrong with the syntax.
If, indeed, you have written ,
"IF paramaterDuck=model1 THEN A=1'-5" AND B=4'-8",
this does not work in GDL.
You can not use "AND" in the right side of the IF....THEN.... statement.
You need to write:
A=1'-5"
B=4'-8"
endif
When I was learning GDL I tried writing a statement like this
and several people explained to me that "AND" is the logical AND
not the additive AND.
Yes, put it in the master script.
I hope this helps,
Peter Devlin
Thanks for the help. THere's more than 1 option so I'll have to look in the cookbook to see how to write that. Would I just need to add and else between each option and end with an endif or an end?
Thanks,
Michele
Michele,
The simplest thing to do is write separate IF statements.
A=1'-5"
B=4'-8"
endif
IF paramaterDuck=model2 THEN
A=2'-5"
B=3'-8"
endif
and so on.
Peter Devlin
Aussie John
Thanks,
Michele
You can only use one else statement which is sandwiched between the if and endif commands
if…
statement A
statement B
else
statement 1
statement 2
endif
Cheers John
[/size]
