clapboard section
i am making an object that is the section of clapboard. i've made the hotspots stretchable but i want the shape that i have put in the 2d script to repeat as far as i want it to along the y axis. what would be the correct funtion to use?
8 Replies 8
Just use a for ... next loop.
for k = 1 to yItems
blablabla ! your script
add2 0, y ! y displacement
next k
del yItems
Same thing for 3D script.
Cheers.
blablabla? not sure if that means i should know to put something there. ummm but all my lines dissappeared
In place of blablabla, type your current script. That's all.
Or if you prefer, at the top of your 2D script type:
for k = 1 to 10 (define your number)
your current script
at the end of your script, type
add2 0, 10
next k
del 10
OK. my lines are back. but it isn't repeating them.
If you are in AC 10, look at the code for DET_Brick Coursing 10.gsm.
You will see what Olivier is talking about.
Peter Devlin
Hi Peter,
@ keenen, i did a mistake.
add2 0, y ! y is the value of displacement on y axis
next k
del 10
Hello Olivier
thanks for the help
