closure in customized windows
Hello every one ,
I have customized a window . it looks good but I have problems I made closure for other default windows
How can I add closure option to my customized windows even by GDL scripting.
thank you in advance.
3 Replies 3
Lingwisyer
Guru
The wall closure might be done through a call script hopefully. If it is, it will be "relatively" simple to add.
Ling.
Lingwisyer
Guru
You will need to incorporate the relevant parameters, which is not the easiest thing to do...
! Draw the Cavity Closure and turned skins
drawindex 50	! Draw Cavity Closure at the top
if gs_bShowNewOnCC & (iTypeDemolitionFill = RENOVATION_FILL_NEW) then
	bCavityCloserLeft	= 0
	bCavityCloserRight	= 0
endif
call "CavityClosure",
	parameters all	refWidth					= refWidth,
					leftWidth					= leftWidth,
					rightWidth					= rightWidth,
					radSill						= radSill,
					radBoard					= radBoard,
					WOD							= WOD,
					offsetSill					= offsetSill,
					offsetBoard					= offsetBoard,
					lineSections				= lineSections,
				! --- Reveal Parameters
					iRevealType					= iRevealType,
					leftRevealPnts				= leftWallholeRevealPnts,
					rightRevealPnts				= rightWallholeRevealPnts,
					iRevealPointsIdx			= iRevealPointsIdx,
					gs_reveal_left				= gs_reveal_left,
					gs_reveal_right				= gs_reveal_right,
					gs_reveal_double_innerLeft	= gs_reveal_double_innerLeft,
					gs_reveal_double_innerRight	= gs_reveal_double_innerRight,
					revealInnerLeft				= revealInnerLeft,
					revealInnerRight			= revealInnerRight,
					gs_reveal_outer_jamb_depth	= gs_reveal_outer_jamb_depth,
					gs_reveal_left_angle		= gs_reveal_left_angle,
					gs_reveal_right_angle		= gs_reveal_right_angle,
					gs_reveal_outerLeft_angle	= gs_reveal_outerLeft_angle,
					gs_reveal_outerRight_angle	= gs_reveal_outerRight_angle,
					gs_mountingFrame			= gs_mountingFrame,
					gs_mountingFrame_depth		= gs_mountingFrame_depth,
				! --- Macro Control Parameters
					bWndCurved					= gs_IsCurved,
					bParalellInCurvedWalls 		= bParalellInCurvedWalls,
					iClosureType				= iClosureType,
					bCavityCloserLeft			= bCavityCloserLeft,
					bCavityCloserRight			= bCavityCloserRight,
					bDrawObjContourIn			= bDrawObjContourIn,
					bDrawObjContourOut			= bDrawObjContourOut,
					bDrawFrameContourLeft		= bDrawFrameContourLeft,
					bDrawFrameContourRight		= bDrawFrameContourRight,
					bCornerWindow				= bRightCornerFunction,
					bLeftCornerFunction			= bLeftCornerFunction,
					fillWallHole				= gs_wallhole_fill,
					penWallHoleFg				= gs_wallhole_pen_fg,
					penWallHoleBg				= gs_wallhole_pen_bg,
					iWallContourLine			= iWallContourLine,
					gs_wcont_line_in			= gs_wcont_line_in,
					gs_wcont_line_out			= gs_wcont_line_out,
					penWallContour				= gs_wcont_line_pen,
					gs_left_oversize			= gs_left_oversize,
					gs_right_oversize			= gs_right_oversize,
				! --- Ganging
					gs_stack_left				= gs_stack_left,
					gs_stack_right				= gs_stack_right,
					gs_bAutoTurnIn				= gs_bAutoTurnIn,
					gs_bOverIn					= gs_bOverIn,
					gs_bAutoTurnOut				= gs_bAutoTurnOut,
					gs_bOverOut					= gs_bOverOut,
				! --- String Resource ---
					stCavityClosureTurnDir		= stCavityClosureTurnDir
Call structure: Window 22 = > GS General Window Macro => GS Corner Window Functions => Wallholestructure
File location: Object Library => Object Library => Macros => Base Macros => CavityClosure
Location is the same for doors and I would assume the same in other AC versions that have the wall closure option.
Ling.
thank you Ling,it seems not easy for me
