‎2009-12-30
07:19 PM
‎2023-05-26
11:25 AM
Rubia Torres
‎2009-12-30 07:44 PM
‎2009-12-30 08:50 PM
‎2009-12-30 08:54 PM
‎2009-12-30 09:35 PM
baranovich wrote:You can lay out the parts flat in the plan view and "Save as..." a library part. This won't help you with the curved openings. It looks like you are using rosettes at the corners so you could use columns at the sides and a profiled wall (for the curve) at the top.
matthew,
thanks alot for your help but im not sure as to what you mean about laying it flat on the floor? attach is an image file that may help you see what i am trying to do.
